-   -   Older Howard cam (http://www.hotrodders.com/forum/older-howard-cam-225665.html)
ionman 11-02-2012 06:21 PM
Older Howard cam
Anybody have an older Howard cam catalog. I have a flat solid grind for a small block Chev and Howards cannot seem to find the specs for it. On the back of the cam it is marked 345G and 1129. Any help will be appreciated.
techinspector1 11-02-2012 08:12 PM
Set it up in a spare block with the crank, one rod and one piston in the #1 hole. Use a timing set to connect 'em and degree the cam with a degree wheel and pointer. A steel rule and feeler gauges will help you find TDC.
E.Furgal 11-03-2012 08:53 AM
U D HAROLD is a member over at team chevelle..
might try p.m.'n him there
