Older Howard cam
Anybody have an older Howard cam catalog. I have a flat solid grind for a small block Chev and Howards cannot seem to find the specs for it. On the back of the cam it is marked 345G and 1129. Any help will be appreciated.
Set it up in a spare block with the crank, one rod and one piston in the #1 hole. Use a timing set to connect 'em and degree the cam with a degree wheel and pointer. A steel rule and feeler gauges will help you find TDC.
U D HAROLD is a member over at team chevelle..
might try p.m.'n him there |
| Need help on installing a modern roller cam in an older big block chevy | 4speed57 | Engine | 2 | 11-27-2011 06:40 PM |
| will this howard cam work for my combo? | chevyrally68 | Engine | 8 | 06-21-2011 06:31 AM |
| Do oem 350 sbc roller cam's take the same cam bolts as older ones? | eric32 | Engine | 5 | 04-20-2009 04:12 PM |
| Help! Identify Older Crower Cam | in2classx | Engine | 3 | 05-18-2008 07:12 AM |
| For JB Howard on the '46 Panel | Bluepen | Hotrodders' Lounge | 0 | 04-28-2004 08:43 PM |
