older small block question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2005, 01:44 PM
I've got an old 327 in the machine shop. It has double hump heads on it. They are either 461's or 462's. I can't remember. My engine builder called, and said I need to locate me an oil filter assembly. He said I need an oil by-pass valve assembly. Where can I get this? Any help will be deeply appreciated.
Old 07-18-2005, 04:48 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
filter?
Is it one of those replaceable filter cartridges or the modern screw on filter? The modern screw on type can be taken off any sb or bb. They are all the same. Make sure you get the two bolts that hold it on. They are a special item.
Old 07-18-2005, 05:47 PM
dawg's Avatar
NAVY VETERAN
you can also get a remote filter assy and mount it on the firewall etc.
Old 07-18-2005, 09:24 PM
The dealer may have one, but be sure it's the one for the older block. There are more than one, and the one for a '72 350 is not the same as the one for a '67 327. I tried it, but it didn't work. I believe the change-over year was '68.
Old 07-19-2005, 08:28 AM
How would this work?
Old 07-20-2005, 10:33 AM
Big Block Z28
I bought one from a Chevy dealer and it ran about $35.00. Probably could have got one from a junkyard for a few bucks.
Old 07-20-2005, 10:54 AM
poncho62's Avatar
Wiki Edits: 5
Pre 68 used a canister type of filter assembly. There were adapters available so you could use a spin on filter. Not all of these were good quality and some didn't allow the filter to work properly, the oil just bypassed it. If using an adapter make sure it is of good quality......I can't remember which were the good or bad ones, off hand.
Ontario Rodders
Old 08-25-2005, 04:10 AM
huh?
Why not just drill and tap the block for the genuine post 67 adapter? it's apart anyway. Poncho62's comments make sense, 68 coincides with the change to large journal cranks across the board.
Old 08-25-2005, 06:54 AM
FRAM & WIX (NAPA) filter companies offer this conversion for a screw on filter.
Old 08-25-2005, 10:35 AM
poncho62's Avatar
Wiki Edits: 5
You can't do that, there needs to be a seal surface for the filter's rubber "O" ring, pre 68 didn't have this....an adapter is necassary.
Ontario Rodders
Old 08-30-2005, 09:12 AM
Biggarmike's Avatar
Chief Procrastinator
The "small journal" blocks (with cannister filter) also have a bypass plate which needs to be installed prior to installing the spin on adapter. I went through this crap with a 67 Camaro I built a few years ago. I ended up just junkyard crawling the complete cannister set-up to avoid separating an original complete assembly. Instead of the cannister, I could have used the bypass and base, an aftermarket filter adapter, and a spin-on.
Big Block Chevy combination question JamesRS Engine 13 01-22-2011 07:08 PM
Big Block or Small Block? help please CUL8R Hotrodding Basics 12 04-05-2005 06:51 PM
big block or small block? jesse01 Engine 5 03-24-2005 06:16 PM
small block ford parts interchange k-star Engine 3 01-16-2004 09:35 AM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
