Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - olds 330
Thread: olds 330
Old 07-29-2012, 08:36 AM
mikey'sf-85 mikey'sf-85 is offline
olds 330
Originally Posted by WDCreech View Post
Is this a case of firing while you are cranking, but stops when you let the key off of start? If so, you're not getting juice through the resister wire to your coil. Been there done that!
Yes little screwy but keeps voltage there at all times while key is on
