Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - olds 330
Thread: olds 330
Old 07-30-2012, 10:40 PM
Rineholio Rineholio is offline
I believe you chucked the distributor in on number one exhaust stroke instead of compression. Pull #1 spark plug, put finger in hole, turn engine until you feel compression, when it's about top dead center check where the rotor is pointing.
The Following User Says Thank You to Rineholio For This Useful Post:
mikey'sf-85 (08-01-2012)
