olds 330 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-01-2012, 10:01 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Simple diagnosis; Remove the #1 plug, put your thumb over the hole, have someone tap the starter until you feel pressure, Use a wrench to turn the damper to the top dead center mark and then take the distributor cap off to see where the rotor is pointing. I'll bet it will be pointing to #6 plug wire.
Olds 330 build-up Disturbed1 Hotrodding Basics 29 03-24-2016 04:38 PM
Olds 403 will 330 heads work? Ulysses 2 Engine 7 05-09-2008 07:28 AM
330 Olds moodier Engine 2 08-09-2004 06:31 PM
Is there a market for 330's ?? Stinky Engine 8 10-12-2003 02:26 PM
olds 330 info (headers, intake...) DusterNut Engine 6 09-07-2003 02:32 AM
