Olds 330 build-up - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-26-2011, 12:20 AM
Hot Rod Has Been
I was pleased to find so much info here and from Fat Hack on the HAMB, too.
I really wanted an early Caddy for the Pontiac but this was too good to pass up...plus it will free up some funds for a dirt track car my son and I want to buy...
Here's a fuzzy pic of the engine...
And the TH400...
  #17 (permalink)
Old 09-27-2011, 11:33 AM
Originally Posted by Mojo56
I know I'm digging up a very old post but I picked up a '64 330 engine today for my '52 Pontiac project..
The engine has a blown head gasket according to the PO... he picked it up for a transplant into a Cutlass he owned but sold the car after he got laid off (familair tune these days).
He pulled the engine/trans from a running, but wrecked, Cutlass...said it ran and drove fine (2 years ago)... anybody aware of any known problems with head gaskets on this engine? Any tips or recommendations? I plan on keeping it stock...it now has a Carter AFB on it but I also got the original Q-jet with it and a good TH400... all for $150.0.
Are you sure it's a 1964 motor? The 64-65 330s only came with the Rochester 4GC square bore carb. The 66-67 motors came with Qjets. No 330 was ever factory bolted to a TH400; they only came with the Super Turbine 300 2 speed AT (which is NOT a Powerglide, by the way). Also, if it's really a 1964 motor, it has the one-year-only no. 1 casting heads that use the oddball shaft rockers. Parts for this valvetrain are nearly non-existent.
  #18 (permalink)
Old 09-27-2011, 01:47 PM
Hot Rod Has Been
The PO, whom I trust, said it came from a '64 Cutlass. I know the trans is not original because the driveshaft has been shortened... probably came from a full size 88.
If it is a '64 I'm not worried about parts availability.... I'm just goin to replace the head gaskets and bolt it back together. The carb is an interesting question... maybe it's a later intake on an early engine.
Time to get some #'s and do some research I guess.
  #19 (permalink)
Old 09-27-2011, 02:08 PM
Hot Rod Has Been
Update...
I pulled a valve cover and it has the later stud mounted rockers so it's NOT a '64...
Still looking for part #'s on the block and heads.
  #20 (permalink)
Old 09-27-2011, 03:53 PM
Hot Rod Has Been
The block number is 381917...early 425? Back to the shop...
Update...
Nope..too narrow at the top of the block...the heads are 66-67 low compression..W 546091 L...that much I have figured out.
So it points to a 66/67 low compression small block engine that has gained a 4 barrel intake and a TH400.... funny how that happens.
  #21 (permalink)
Old 09-27-2011, 04:04 PM
That is the number on my 66 330.....381917
  #22 (permalink)
Old 09-27-2011, 04:16 PM
Hot Rod Has Been
Hey... here's the guy that started this old thread!
I'm pretty sure it IS a 330... one Olds FAQ page said the block was an early 425 (?)...the question mark was theirs not mine...it's NOT a 425.
  #23 (permalink)
Old 09-27-2011, 06:52 PM
I had High compression 330 in '67 cutlass. Before I pulled it apart for rebuild it would still burn the tires and believe it or not had several broken rings. Fun rebuild, fun motor and I removed the cushions from the Super Turbine 300
The Following User Says Thank You to 52fatness For This Useful Post:
Ilike2tradem (03-24-2016)
  #24 (permalink)
Old 09-28-2011, 12:46 PM
Update...
All the 330 heads have the same 64-ish CC chambers. There are no "low compression" heads. The CR was varied with different size piston dishes.
  #25 (permalink)
Old 10-05-2011, 12:23 PM
Hot Rod Has Been
I may pull it down next weekend... will be interesting to see what the problem is. there IS some rust on the top end from moisture... so the head gassket problem is probably accurate.
  #26 (permalink)
Old 10-05-2011, 12:28 PM
Yes, it's me!
Still don't have the motor complete, or car done. But We just bought a new house, 2 car attached garage, 4 car detached garage, and I have been working on it like crazy. 307 and tranny ready to pull, then I can go get all my motor and goodies from the friends house. I didn't have room where I lived previously for doing anything (apartment) so he has had it stored for me. Hopefully in the next few months, she will be going. Have a 71 455 and THM 400 I picked up cheap a year ago, as well. It's sitting in the detached, ready for a tear-down, and another project to go into.
  #27 (permalink)
Old 10-05-2011, 04:29 PM
Hot Rod Has Been
Yes, it's me!
It took me 40 years to get my own shop...bigger than my house but still too small...
  #28 (permalink)
Old 08-05-2014, 03:01 PM
I am not able to post here as often as I would like, but I have done more work on the 330, and just need to finish plumbing and wiring. I can actually crank it over right now, just to hear it turn.
  #29 (permalink)
Old 03-24-2016, 01:14 PM
Olds 330ci high compression alcohal torque monsters!
I am glad to have found this forum thread! I have a Dave Smith custom lightweight hood. And Oldsmobile 330CI High Compression Alcohol Forged V8 Race Engine | eBay motor built by Bob Warren in beaver dam Wisconsin. Sweet info on this thread!
  #30 (permalink)
Old 03-24-2016, 05:38 PM
Cars, Trucks, Boats
The old Olds thread that refuses to die... LOL !!! .. I used to have a '65 Cutlass convertible with the standard 4 bbl. high compression 330" engine... but the 2 speed auto tranny made it irritating to drive...
57 Olds 371 build up El Raton Engine 1 05-23-2006 11:36 AM
86 olds build up brian?smith Introduce Yourself 2 01-02-2006 08:01 PM
327 build up using 1964 and earlier parts ONLY chopperimpala Engine 23 10-06-2005 02:07 PM
Build a kit car Dutchman General Rodding Tech 9 09-23-2005 05:39 PM
First Rod Build - T Bucket , here we go Gr8lite Hotrodding Basics 10 06-29-2005 03:42 PM
