Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Olds 330 build-up
Old 03-26-2007, 10:47 AM
joe_padavano joe_padavano is offline
Harlan Sharpe makes the best Olds rockers. When you get pistons, be sure to account for today's thicker head gaskets in your compression ratio. Aftermarket pistons are usually rated with the thin metal OEM head gaskets, but today most people use the FelPro head gaskets with 0.040" compressed thickness. This usually drops compression about a half point from advertised. Olds exhaust ports are awful; I like to use a dual pattern cam to make up for this. Mondello does have a good selection of cams.
