Hi,
This is one reason to pre oil an engine. I think that since you didn't soak the lifters in oil, or borther to pre oil, you may have air trapped in the lifters, you can either use a drill run pre oilier, that you can get at auto zone as a loaner, & try & get the air out, or put oil on the rockers & start it up, it should clear the air out in a minute or so. Rich |
Weak oil pressure
You might look and see if the oil galley plugs were installed in the front of the block.... The plugs were probably removed for cleaning and not put back. This will let the pressure drop off behind the timing chain and be good at the port where you are getting your oil pressure. The solid one goes on the left front and the one with the hole on the right. The mains feed around the left galley so running the engine too long like this will starve the front mains and rods. The small hole in the right plug oils the timing chain.
Dan Hurst |
Hurst, thank you for the info and others as well. We did prime the motor with the drill method prior to starting the engine. I have a feeling these plugs you mention may be the culprit. I'm not familiar with this engine, but where are these plugs located? Is it behind the timing chain cover on the block? What should I look for, if there is a plug or not a plug. Thanks again for the help.
The plugs are located behind the top timing gear at the ends of the lifter oil galleys. If you just see threads at the end of the oil rails then the plugs are missing. I tried to find a picture for you with no avail.
Dan Hurst |
Hi,
Although I don't think this is the problem, here is a picture of the plugs, just because it could be. Rich http://www.chevyhiperformance.com/te...ics/index.html |
Kleen56,
Although you said you primed the oiling system, you apparently stopped before you had oil coming up to the valve train, as you said it was dry, sometimes it takes a lot longer to get oil up then you would think, because most people can only relate to starting their engine & seeing almost instant oil pressure, well that won't happen using a drill to run the oil pump, when you were pre oiling did you have a gauge attached so you could see if you were making pressure? & not to insult you, but were you turning the pump in the right direction? along with rotating the engine buy hand while priming? |
Wouldn't put it passed him. The only question I have, is he started and ran the engine for several minutes including revving it up on occasions. I would think that should of primed the engine running that long? I know he is running a high volume oil pump and I read that could be a cause for blowing out those oil plugs as well. I believe he's going to pull the timing cover and see if the plugs are there or not. He's convinced that is the problem. Heck, it'll give him something to do! I heard the engine run and it sure sounded nice for not getting any oil to the rockers, etc.
I'm not that knowledgable about Olds, I'm a chevy guy, but I do know that there is a difference between Pontiac and Chevy lifters that relates to the height of the oil band cut around the body of the lifter and its alignment with the oil passage that will cause oiling problems if you try to use chevy lifters in the Pontiac. Might be a similar thing, they all use the same diameter lifter. Just another area for you to explore for problems. Try www.realoldspower.com
| Oil leak in 350 Chevy | Ed Baltera | Engine | 18 | 07-29-2012 11:24 AM |
| My 350 Is Still Using Oil Somewhere | HJCHEVY400 | Engine | 19 | 09-03-2007 11:05 PM |
| Environmentally friendly honing fluid. | F-BIRD'88 | Engine | 16 | 07-01-2007 10:06 AM |
| Olds 350 Leaking Oil Out Of The Water Pump | SBC | Engine | 7 | 06-21-2007 05:30 PM |
| valves sucking oil | wrenchturner | Engine | 3 | 05-27-2002 04:42 PM |
