Olds 350 Diesel Converter behind Chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2011, 01:36 PM
FastOrange's Avatar
Anyone know what stall speed a Olds 350 diesel Torque converter would be behind a Chevy 350?
Old 03-18-2011, 05:17 PM
SSedan64's Avatar
Rated @1400rpm behind the Deisel, may be lower behind SBC.
This Trans could also be a TH350C w/Lockup TC, check for an electrical plug on the driver side of Trans.
Lockup & Non-Lockup TC's do not interchange, the Input Shaft on the Trans is different.
Old 03-18-2011, 08:20 PM
FastOrange's Avatar
Ok i will check.
Olds 350 diesel to gas vibration problem destrux Engine 21 10-22-2010 02:15 PM
455 Olds repower for 5.7 Diesel - Headers? 66GMC Engine 2 12-25-2005 08:15 PM
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 08:52 PM
Oil pan Olds gas/diesel ? Nailhead2x4 Engine 1 02-08-2005 08:51 AM
Converter, diesel vs gasoline Norwegian Transmission - Rearend 1 10-29-2002 01:24 AM
