-   -   Olds 403 Help (http://www.hotrodders.com/forum/olds-403-help-4672.html)
WS6tech 11-20-2002 04:30 PM
Olds 403 Help
Hey guys new, member here. I just pulled the 403 out of my 79 Trans Am. Heres my build up so far:
1.SSI 224/234 flat-tappet cam
2.Olds 350 heads w/64cc chambers
3.TH350 tranny
4. 2.07/1.625 valves (heard they will fit)
5. 3.73 gears
6.Holley Avenger 770
7.Edelbrock Performer
How does that sound so far? ANy good piston recomendations??? (flat top)
BOBCRMAN@aol.com 11-20-2002 07:28 PM
if you put flat top pistons in an olds you will probably have to run it as a diesel, seriously the chambers in the olds are small so you have to run a dish piston.
WS6tech 11-20-2002 08:23 PM
I have to run dished in Olds 350 heads??? I had no idea. Would the compression just go through the roof if I went flat top???? If I stay dished, I'll just wire wheel and clean the dished pistons I have now....
Wmarden 11-21-2002 01:38 AM
I don't know the answer but I can say ask at the oldsmobile mailing list. Below are the instructions for subscribing to the list
Individuals can subscribe and unsubscribe from the Oldsmobile list
directly. All membership requests are to be sent to majordomo and not the
list itself.
Send subscribe or unsubscribe requests to:
majordomo@chebucto.ns.ca
Include one of the following as the only text in the body of the message:
subscribe oldsmobile
subscribe oldsmobile-digest
unsubscribe oldsmobile
unsubscribe oldsmobile-digest
WS6tech 11-21-2002 01:16 PM
thansk guys frot he mailing address. I searched all posts with "403." It seems as if a lot of people here know what they are talking about. I just can't understand how chevy can have flat-tops with 64cc chambers. I do realize the head designs may be different though.....So basically, has anyone here run flat tops on their 403(not with 83cc smog head). IF it won't work, I'll get some forged dished...
WS6tech 11-21-2002 02:25 PM
any 403 boys know the answer??
BOBCRMAN@aol.com 11-21-2002 05:13 PM
call J.E. pistons tech line they can tell you what you need to know.
WS6tech 11-21-2002 07:29 PM
ok...I'll probably ending up getting KB forged pistons with moly rings....
