Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 05-08-2008, 05:14 PM
Ulysses 2 Ulysses 2 is offline
Olds 403 will 330 heads work?
I have an Olds 403 in an 86 Cutlass. I want to get more power out of it but I cant find any 68-72 350 heads, but I can get a whole 330 rocket heads for really cheap. Will they work on the 403? The 330 was made in the 60s and the heads have small combustion chambers so they will help the compression ratio on the 403 alot, and I can do port and polish job to make them flow better. I know the 330 is a rare engine but someones gotta know if this will work
Old 05-08-2008, 05:19 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
JackOfAllTradesMasterOfNo ne
re: Olds 403 will 330 heads work?
Old 05-08-2008, 05:30 PM
If they will work on a 307 they will "bolt up" to the 403 but will the compression ratio be too wild for the street? The car already has a cam that barely lets it idle, so I want to keep it streetable.
Old 05-08-2008, 05:36 PM
SSedan64's Avatar
I don't know sqwat about the Olds engines but this post has more Info. Or do a search for more.
http://www.hotrodders.com/forum/rec...l?highlight=307
Old 05-08-2008, 06:00 PM
joe_padavano joe_padavano is offline
The 330 heads are virtually identical to the 68-70 350 heads. Watch out for the oddball 64 330 heads that used the one-year-only shaft rockers. You should install the big-block sized W-31 valves in these heads.
By the way, the 330 also has a forged crank with the same stroke as the 403...
Old 05-08-2008, 06:06 PM
Thanks for the fast info! Are the pistons the same hight on the 403 and the 330? It sounds like Im going to get the 330 now, how much does raising the compression ratio a point or 2 help the engine's power?
Old 05-08-2008, 07:08 PM
Mustangsaly's Avatar
Mustangsaly Mustangsaly is offline
check the for sale section at www.realoldspower.com for heads. Olds info here http://www.442.com/oldsfaq/ if you see non for sale ask.
Old 05-09-2008, 06:28 AM
Yes, all the small block Olds motors use the same compression height on the pistons as well as the same stroke and same rod length, however the 403 rods are beefier than other SBO rods (not counting the diesels). They will work on the forged 330 crank, but you will need to rebalance. Also, the 64-67 Olds motors use a different crank flange bolt pattern than the 68-90 motors, so you need to use the flywheel that matches the crank if you decide to swap.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Olds 403 will 330 heads work?"
Olds 330 build-up Disturbed1 Hotrodding Basics 11 04-03-2007 07:20 AM
olds 350 #7 heads?? Rough-Rider Engine 1 01-25-2007 03:19 PM
71' 350 #7 olds heads on 79' 403 olds Rough-Rider Engine 5 01-22-2007 03:04 PM
olds #5 head johann Engine 2 07-31-2006 09:55 AM
olds #5 head johann Engine 1 07-30-2006 09:05 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
