olds 442 stands for.....??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2006, 03:58 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
OK, so all my short life, i've heard that 442 stood for 4- four barrel carb, 4- speed trans, 2- dual exhaust.... well, this past weekend i think it was, on speed channel, they did a show on the oldsmobile. They showed a vintage commercial, in the commercial, the announcer states, "Olds 442- 400 cubic inches, 4 barrel carburation, 2 true dual exhausts".... wth olds guys?
who knew?
Old 04-19-2006, 04:12 AM
The first year was 4 speed only, then when Olds upped the capacity to 400ci and made the auto an option they changed the meaning of the designation.
If my memory is correct, a 1977 442 (probably the best looking Nascar Olds ever) could be ordered with a 260 v8 and 5 spd - yuk.
I know little of Oldsmobiles history but I'm pretty sure '64 was the first 442 with 340 cubes, followed by the 400 in 65. Remember GM wouldn't allow over 400 cubes in intermediates until 1970. Copo or outside vendors like HURST/OLDS were exceptions.
Old 04-19-2006, 08:22 AM
Wiki Edits: 31
it does mean 4bbl, 4spd, 2 exhaust
Old 04-19-2006, 10:04 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Yeah that's an error on their part. Should have been obvious enough to them that it was incorrect.... given that there are 442 cars with fewer than 400 CID.
K
Old 04-19-2006, 04:42 PM
TailGater's Avatar
Blood, Sweat, and Gears!
I think they changed the designation again with some of the front wheel drive 442's as well, found this on 442.com. http://www.442.com/oldsfaq/of442.htm#442%20Meaning(s)
Chris
Old 04-19-2006, 04:49 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
thanks for the kool link.
1990 and 1991 (FWD 442)
4: Four cylinders
4: Four valves
2: Two camshafts
YUKKKK!!! A DUKKKK!!
How can they take somthin' so nice & make it so wrong?
R
"SlowRide66"
"Illegitimis non carborundum"
Old 04-19-2006, 05:02 PM
BigBlockBabe's Avatar
Missing You
That's a good question. I was reading in the new Car Craft that Ford is coming out with some new minivan and calling it a Fairlane.
Old 04-19-2006, 05:10 PM
Rob Keller's Avatar
Wiki Edits: 38
R
"SlowRide66"
Old 04-19-2006, 08:59 PM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
Before 1968 - 4 spd., 4bbl., dual exhaust.
1968 and after - 400, 4bbl., dual exhaust.
I have a 1969 442 in my shop now. It has a 400 and an auto.
Old 04-20-2006, 12:41 AM
Gr8 '48 bow tie's Avatar
Be American, Buy American!
I thought it was:
4 stuck valves
4 flat tires
2 men pushing
and a dead partridge in a pear tree.
Old 04-22-2006, 04:38 PM
re: olds 442 stands for.....???
From someone who was there at the time and cared enough to remember -- when first introduced, it was FOUR barrel, FOUR speed, and TWO exhausts. Whatever convoluted marketing stuff they came up with later, the factory reps explained over and over at the start -- it was 4 barrels, 4 speed, 2 exhausts.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
OLDS 442 w-30 help !! RedRobster Hotrodding Basics 5 11-13-2005 08:02 PM
68 olds 442 bear1968 Electrical 1 01-26-2005 03:22 PM
68 olds 442 bear1968 Electrical 2 01-22-2005 11:17 PM
Advice on Differential for (GM) 1967 Olds 442 - Need New One 67olds442 Transmission - Rearend 10 07-19-2004 09:47 AM
