Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - olds 455
Thread: olds 455
Old 01-01-2005, 11:34 AM
dubya30's Avatar
dubya30 dubya30 is offline
Joe Mondello - www.mondellotwister.com
Dick Miller - www.dickmillerracing.com
www.realoldspower.com
www.oldspower.com
www.442.com
All great oldsmobile informational websites....
Oil restrictors should not be necessary unless you spend a lot of time above 3000 RPM. DO NOT put in a high volume oil pump. Olds engines have a problem with sucking too much oil up to the top and not returning very well. A high volume oil pump will only make things worse. There is no reason to not get a larger capacity oil pan with a pickup that goes with the pan. Also be sure that your pickup is set correctly.
