OLDS 455 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2002, 07:51 AM
apprentice geezer
Post OLDS 455
HAVE OLDS 455, STOCK SHORT, EDLEBROCK ALUM HEADS, EDLEBROCK INTAKE, MILODON "CHEATER" GEAR DRIVE, MONDELLO JM-499-B CAM (230/232 @ 0.050 ) INSTALLED 4 DEG ADVANCE, ROLLER ROCKERS, HEDMAN HEDDERS, HOLLEY 870 VACUUM CARB, TH350 W/SHIFT KIT, HEI W/MOROSO CURVE KIT, RUNNING 16 DEG INITIAL ADVANCE.
ALL HARD PARTS PURCHASED FROM MONDELLO AS A
STREET PERFORMANCE KIT.
SHOULD SCREAM ! IN ACTUALLITY RUNS WORSE THAN WHEN WAS STOCK (IS 76 MOTOR) (HAD HEDDERS & DIST KIT PREVOIUSLY) (SAME TRANS). HAVE CHECKED INSTALLATION OF ALL BOTH SELF AND HAD MECH RECHECK, ALL INSTALLED AS SHOULD BE.
ANY HELP PLEASE, AM RUNNING @ 5000+ FT ALTITUDE.
Old 11-10-2002, 09:24 AM
New Member
Post
the cam was installed straight up? or u installed the extra 4 deg.?most cams alrerady have 5 deg. advanced
have u checked for vacuum leaks?
collapsed lifters?
vaves seating all the way?
valves adjusted properly?
i just built a pontiac 455 last week with 16 heads and a comp cams valvetrain package, im still workin the bugs out but i had all those probs when it was first put together, includeing collapsed lifter and it was new
the new heads vaves werent seating right and it ran like ****
now that most of that is fixed it runs like a raped ape!
Old 11-10-2002, 09:44 AM
roys63's Avatar
Post
Are sure the cam timing is right?Does it respond when you first get on it?or stops pulling at a certain RPM? What is your total timing @3000 RPM i think you need about 32-38. And the valve adjustment. be sure you don't have to much spark timing.Don't let the bugs get to you!
Old 11-10-2002, 01:08 PM
Post
Be sure you check your total timing. The big Olds usually doesn't like more than 32 to 34 degrees total.
Old 11-10-2002, 04:35 PM
apprentice geezer
Post
CAM INSTALLED @ 1 DEG ADVANCE, ALLOWS FOR 1 DEGREE RETARD AS WEARS IN, GEAR DRIVE WILL ALLOW ONLY 2 DEGREE INCREMENTS, (STRAIGHT UP IS 3 DEGREES BTDC, IN @ 4 DEGREES BTDC.
HAVE TRIED IGN TIMING FROM 2d TO 16D STATIC, NOT MUCH CHANGE.
CRANKING COMPRESSION PRESSURE IS GOOD.
HAVE CHECKED AND RECHECKED THE LIFTERS, ADJUSTMENT IS 1/6 TURN PRELOAD. (0.006")
SEEMS TO BE A LOT OF REVERSION THOUGH. DON'T QUITE KNOW WHY.
NOT MUCH VACUUM, (AM @ 5000+ FT).
NOT MUCH ADJUSTMENT IN CARB.
STILL FRUSTRATED AND CONFUSED !!! <img src="graemlins/drunk.gif" border="0" alt="[drunk]" />
Old 11-10-2002, 07:40 PM
Post
Is there any possibilty that your exhaust is plugged up? I had a problem with a baffle in a muffler breaking loose and it plugged the muffler.
Caused a lot of reversion, and no power. Wouldn't rev.
Old 11-10-2002, 09:00 PM
Post
You had me scratching my head until I read that you are at 5000 feet. Thats up there. You said your compression is good...how good? You also said that the motor ran better stock. Well that stock cam has less overlap than your present cam. What were your stock compression figures? Unless you run very high rpm, you just might have to go with a lesser cam because of your altitude.
Old 11-11-2002, 05:01 PM
Post
you said that you had headers previously,i hope that you are still using them. i've had motors that took me more than a month to get to run the way i wanted them to. it's probably something little,just keep working on it you'll figure it out
Foot to the floor,hair back,knuckles white.
