Olds 455 electric water pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2008, 08:45 PM
81RocketBonneville's Avatar
I have an electric water pump for my Olds 455 and I don't know what to do with the hoses that the mechanical pump used. The electric pump just pumps from one side to the other, where does the lower radiator hose and the intake hose go??? Help!
Old 12-18-2008, 08:36 AM
It doesn't just pump from side to side. There should be an inlet someplace on the pump that hooks up to the lower radiator hose. The electric pump will not have the heater hose connection nor will it have the bypass hose connection that goes to the thermostat housing.
Old 12-18-2008, 06:32 PM
yea, you've gotta have a neck for the water intake. You don't pump water from one side to the other. As far as the other hoses, well, you can bypass or cap off or plug your heater hose and necks. As far as the thermostat bypass, you can cap that off too, but I recommend that you drill a couple small holes in your t-stat just in case.
Water pump inlet extension steve392 Engine 4 05-05-2008 02:31 PM
HELP QUICK Electric Fuel Pump Leaking 66 T-Bird Engine 4 06-06-2005 06:26 AM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 09:34 AM
