Olds 455 engine power steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2007, 01:59 PM
Need help putting power steering pump back on engine. It is an Olds 442 w/455 engine, no air. Does anyone have a diagram of this engine?
Old 02-20-2007, 03:57 PM
The PS pump bracket is three pieces. It attaches to the block in four places. There are two threaded studs on the front cover, a tapped hole down low on the side of the block, and a bracket that goes to the front bolt on the exhaust flange. There is a spacer that goes over the bottom threaded stud and another that goes between the side of the block and the bracket. Be sure to loosen all the bolts holding the bracket together before you try to put it on the motor. Tighten everything after all the bolts are started.
new power steering pump questions HARVICKx29 Suspension - Brakes - Steering 3 09-05-2005 03:22 PM
olds aurora power steering noise? J. Eaton Electrical 1 11-28-2004 05:37 PM
50's Chevy truckw w/ power steering ? Slickriffs Suspension - Brakes - Steering 3 10-13-2004 05:18 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
help with 455 olds marine engine 442 chevy power Engine 1 01-03-2003 06:59 PM
