Olds 455 with holley 750 dripping fuel when shut off?!?!? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2012, 12:13 AM
Hey guys, I always seem to get some good answers on here when i have a problem. I put an olds 455 in my 52 chevy fleetline. I have a holley 750 double pumper. When the car gets warm and i shut it off fuel keeps dripping from the carb into the engine flooding it. I have a fuel pump without the return line on it. Is the fuel pressure too much without the return on the fuel pump? I am going to check the float levels tomorrow but i want to make sure it is not a problem that i am running a fuel pump without the return line since the stock pump has a return line on it. Running a return line is not an option since i have no spot on my gas tank for a return line.
Old 07-22-2012, 02:45 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Make sure the gas tank isn't under pressure from heating up w/a non vented gas cap on the tank.
Old 07-22-2012, 07:33 AM
Thanks guys i am gonna play with it today.
Old 07-22-2012, 07:51 AM
What kind of pump?
Should install an inline fuel pressure gage to see what is going on.
Old 07-23-2012, 05:53 PM
All fixed up guys. Put a fuel pressure regulator on it and its good to go
Can Holley Power Valves stick shut? Argess Engine 2 09-01-2009 11:02 AM
fuel dripping from primary booster nozzles GMR Hotrodding Basics 2 06-13-2009 08:38 AM
Fuel Economy/Tuning - Olds 455 fearsomefairmont Engine 2 03-06-2005 04:50 PM
Olds 455 vs. Pontiac 455? bildo95 Engine 3 06-27-2003 05:53 PM
74 olds 455 little line on fuel pump 225buick Engine 2 04-09-2003 09:23 PM
