Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Olds 455 Oil Restrictors
Old 04-04-2009, 08:26 PM
ezobens ezobens is offline
I am in the process of replacing the bearings in my Olds 455 powered jet boat.
It appears that the previous owner put the Mondello main bearing restrictors in mains 1-4. Has anyone used these before?
I'm questioning if the restrictors have been pressed far enough into the galleys.
I enlarged the upper bearing oil holes to 5/16" but the restictors still don't line up with the holes in the bearings and I am concerned if I will have enough oil flow to the bearings (see attached photos).
Since I'm replacing the bearings due to apparent oil starvation on the #4 main, I want to make sure I don't run into the same problem again.
Any suggestions or advice would be much appreciated.
Thanks!
Elm
ID:	37416   Click image for larger version
