Olds 455 or pontiac 400/400 - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 02-02-2010, 12:12 AM
Originally Posted by WDCreech
You don't need a stroker to make 450 hp. You can make that horsepower with a 400, easy, but it would have better street manners with 455 cubic inch.
I have no dought in the power of the 400. Its just that everyone that asks about the 400 gets pointed to the stroker. I would love to do a stroker but I can aford it (High school kids ). I assume that by steet manners you mean loosing some bottom end power?
  #32 (permalink)
Old 02-02-2010, 01:00 PM
Originally Posted by cobalt327
EDIT- I wonder if anyone here (Joe) knows if that engine had "big" valves, like one suspect site says...
Yes it does. All Toro motors got the big valves that year.
  #33 (permalink)
Old 02-02-2010, 08:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks, I'll file that nugget away.
AFA $500 for the 'wet' Olds 455- no way! I would think under the circumstances the owner might take considerably less than that! But if he won't budge on it- screw it, do the Pontiac.
There's no way I personally would put anything more than a tune up in the 403. A Pontiac (any 350-up) is a MUCH better engine than a 403, IMO.
  #34 (permalink)
Old 02-02-2010, 10:20 PM
Well I would like to build the 400 but its getting expencive. I cant afford the stroker and it seems like no one else has a build for 450hp on a stock block. I was thinking doing the usual. I found a pair of 6x heads, witch is better the 6x or these 1970 "16 code" heads? I was thinking of picking up the better flowing heads. doing a 30 over bore, flat tops, nice cam, headers, new H.E.I, mabye a intake and set it on a 750 or 800 cfm carb. What do you say. I need some help in the cly heads department and cam department. I just need enough vacume for power breaks.
  #35 (permalink)
Old 02-02-2010, 10:36 PM
Forgot to say that This is most likely going on a '75 block
  #36 (permalink)
Old 02-02-2010, 10:45 PM
Sorry once again, I ment to say '74 block
  #37 (permalink)
Old 02-02-2010, 10:51 PM
WDCreech's Avatar
Grumpy Old Goat Herder
A '75 block, if cast early enough, would be a good block. Give us the castin number of the block, shown below, and post it on here, and I'll tell you if it has the the thin main webbing. It will be either 488986 or 500557. If it is the 557 block, it would only be okay for mild street use. If it's the 986, you're good to go!
  #38 (permalink)
Old 02-02-2010, 10:58 PM
Sorry Its a '74 block. I cant get the cast #s because I am looking at it on kijji. I think from what I here that the 74 will be ok. I just need some help on the cyl heads and cam now. Any suggestions?
  #39 (permalink)
Old 02-02-2010, 11:07 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Look for another identifier on the 6X heads to tell you a bit more about them- they came in several different chamber sizes.
The 4, 6, 7, 8, and 9 identifiers can be found stamped on one of the vertical ribs on the side of the head.
  • 6X-4 93cc (mine measured 95cc that I had on a 455), they came on mid-'75-'77 350ci; '77-'79 W72 (TA "6.2 Litre" option) 400ci.
  • 6X-6 124cc
  • 6X-7 93cc
  • 6X-8 101cc
  • 6X-9 101cc
6X heads have hardened exhaust seats, screw-in rocker studs and guideplates, 2.11" intake x 1.66" exhaust valves.
There are also 1973-'74 cast #4X heads w/98 cc chambers and screw-in studs.
I'd avoid the '70 #16 heads- they are not a good HP choice, they have small valves and might even have pressed in studs.
There is more in a thread HERE, as well as other info on this forum- hit up the search for 'Pontiac 400', etc.
  #40 (permalink)
Old 02-02-2010, 11:10 PM
alright let me see what I can find out. Once again its a add on kijji so I will just give the guy a call tom.
  #41 (permalink)
Old 02-02-2010, 11:26 PM
WDCreech's Avatar
The '74 block will be good to about 700+ hp. Your best bet for heads are '73-'74 #46s (screw in rocker studs), #4C-5 (pressed in studs), '75 5C-4 or 5C-7 (screw in), or '75 6X-4 or 6S-7 (all had screw in studs after a B215 casting date). This is where to find head specs: http://www.wallaceracing.com/headsearch.htm
  #42 (permalink)
Old 02-02-2010, 11:53 PM
Thanks alot, I will keep a eye out for any of these heads. The only engines I can find are 74's-75's. I uses the link you send and it showed every ****in head eccept the ones you mentioned. I came up with:
. 4c
. 4x (screw in stud)
. 5cx
. 5c
. 6s
Are any of these heads good? I was just punchin in 1974 and 1975 400 blocks. Should I look at the 455's as well?
  #43 (permalink)
Old 02-03-2010, 12:11 AM
WDCreech's Avatar
The secondary number that I gave (after the dash) are a stamped number on the verticle rib near the left side of the head. Look at the illustration that I posted. You may need to clean it off with a wire brush to beable to read it. Heads from a 455 will have too big of a combustion chamber for a 400. A 350 smog head would work best.
  #44 (permalink)
Old 02-03-2010, 12:16 AM
Alright, I guess I will call these guys up and see what the deal is. How much hp do you think I will reach with the 400 done up with the heads you suggested with some .30 flat tops a nice cam, intake and headers?
  #45 (permalink)
Old 02-03-2010, 12:30 AM
WDCreech's Avatar
With a stout hydraulic roller, or solid flat tappet cam, and a 700 or 750 cfm carb, you should get 430 to 450 hp. You'll need 3.73 to 4.10 or better gears to have a good bottom end.
Pontiac 400 vs. Pontiac 455 chevyelc81 Engine 7 03-19-2011 08:31 PM
Olds 455 vs. Pontiac 428?? 428BIRD Engine 4 04-06-2007 05:06 PM
olds 455 oldscutlass General Rodding Tech 7 01-01-2005 12:34 PM
Olds 455 vs. Pontiac 455? bildo95 Engine 3 06-27-2003 05:53 PM
will a 1969 455ci olds engine bolt right in place of a pontiac 400??? chevyelc81 Engine 3 06-12-2002 04:54 AM
