Olds 455`s are undersquare engines, meaning the stroke is greater in inches than the bore. With it`s good sized 4.125 inch bore and long 4.250 inch stroke, it`s a torque monster. Put the right pieces in it`ll shred the tires off that thunder chicken (firebird) with ease.
Not to take anything away from the Olds 455, as it is a very powerful engine with a lot of torque, but if it has had water in a cylinder, it will need a complete rebuild. Boring, new pistons, and possibly one rod, if it hydro locked. The 400, on the other hand, unless it's been rebuilt, has cast pistons and rods, and if you're going to build it for performance, at the least, the pistons need to be changed. Performance isn't cheap, anyway you look at it!
Bill
Bill |
Bill |
They can be purchased balanced and in just about any configuration that you want. |
I'm an Olds guy, but even I think there should be a Pontiac motor in a Firebird. If the 81 was originally a 301 motor, you should have all the parts needed to bolt in a Pontiac 400 or 455. The Olds motors in Firebirds use the Chevy-style frame mounts with an Olds-unique bracket that bolts to each side of the block and adapts to the Chevy frame mounts.
It's a SHAME the 455 got wet! Otherwise, that engine w/nothing but a set of pipes and maybe an intake (not that it really needs it, any more than the Pontiac would, as long as they're 4-bbl intakes) would run great in the T/A- even (especially, I should say) w/those highway gears that are likely in it now.
I put a basically stock Olds 455 from a wagon, into a 1976 Cutlass (buckets, console, nice ride- but HEAVY) when the Buick 231 went south. That car was an animal. But if the Olds was wet long enough to lock it up, like everybody says, it'll take a bore and pistons/rings to put it right. But before you do anything, you might want to go ahead and pull it apart to see exactly what you have. You just never know... But be prepared for the worst. |
Well I would really love to get te 455 but with the whole wet thing I am really worried. I dont wanna get screwed with the 455. The last thing I need is another boat anchor. IF the 455 came un stuck after soaking with the diesel I will pick its up. I was thinking a couple of things though. If the diesel fuel didnt work what are the chances of engine oil, alot of wd 40, break fluid or as much as I am afraid mabey some light heat? I dont mean mix them all togeather I just mean witch is most likely to work? Another thing I was wondering is what it would cost to bring the 400 up to the 500hp mark like I was going to do with the 455 compaired to the cost to just rebuild the 455? Finaly though, If The 455 is stuck why not just take the E heads on it, get some flat tops and put them on the 403 with a new cam and headers? It would save me some money not having to pay another $500 bucks for a 400 and it would put me around 450hp or more. I was thinking that if I go this way and do the 403 I would just use it untill it blows up and then get a 455? |
| Pontiac 400 vs. Pontiac 455 | chevyelc81 | Engine | 7 | 03-19-2011 07:31 PM |
| Olds 455 vs. Pontiac 428?? | 428BIRD | Engine | 4 | 04-06-2007 04:06 PM |
| olds 455 | oldscutlass | General Rodding Tech | 7 | 01-01-2005 11:34 AM |
| Olds 455 vs. Pontiac 455? | bildo95 | Engine | 3 | 06-27-2003 04:53 PM |
| will a 1969 455ci olds engine bolt right in place of a pontiac 400??? | chevyelc81 | Engine | 3 | 06-12-2002 03:54 AM |
