Olds 455 stalling when driving - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2010, 08:20 PM
81RocketBonneville's Avatar
I have an Olds 455 in my Bonneville that have been giving me fits since I got it running two years ago. The latest issue is stalling. I took my car out for a drive one night, a joy ride for about 20 miles or so. I was driving very conservatively and not getting into the throttle much at all. After about 15 minutes of crusing the engine lost power and stalled. After I parked I couldn't get it started for about 5 minutes or so. Once back on the road it stalled again a couple of minute later. This happend four times until I finally made it home.
I'm think that heat has something to do with it since the engine will restart after a few minutes of cool-down time. I had the carb (Holley 770cfm) and intake off recently to change a broken pushrod. During reinstallation i used a gasket sealant on both mating surfaces and a new gasket for the carb. I have a Holley heat shield kit with a thick spacer inbetween the carb and intake as well.
The engine is very hard to start cold but once it gets warmed up it runs pretty good. I never had it stall when in the garage, only when I'm out driving. Anyone have any ideas on what this could be???
Old 07-19-2010, 11:22 AM
If you're running an HEI distributor, my first guess would be a bad ignition module.
Old 07-20-2010, 02:19 AM
chevykid90's Avatar
454, what turns your crank?
Last journal entry: Replacing bearings and crank
yup, thats what i was going to say. had an old jeep that used to do the same thing. changed dizzy, all the wires, everything and it wasnt until i bought a new coil when it stopped. the coil was just going bad, (or was bad already).
Old 07-24-2010, 05:49 PM
Thanks guys! I put the distributor from my 307 in and it started and ran great. I can't drive it though beacause it is computer controled and I have no advance.
My Accel Dist is just 1 year old!!! I don't see how it could crap the bed so quickly.
Olds 455 vs. Pontiac 428?? 428BIRD Engine 4 04-06-2007 04:06 PM
455 Olds timing marks 71cutlass0159 Engine 6 01-26-2007 06:59 AM
best performance for olds 455 !!!!!!! 66 442 Engine 3 12-20-2006 01:20 PM
455 Olds repower for 5.7 Diesel - Headers? 66GMC Engine 2 12-25-2005 08:15 PM
455 olds Vs. 500 caddy HELP! Kenny13z3 Engine 9 10-05-2004 05:15 PM
