Hotrodders Bulletin Board > Tech Help> Engine
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 06-24-2004, 11:52 AM
hotrodder442 hotrodder442 is offline
olds 455 timing ?
I bought an olds 455 engine from a friend and had it bored 30 over ; put in better pistons ; a mid range cam ; an edelbrock performer intake with a 770 street avenger carb. The engine block numbers are 396021F with G heads. I've been told it's a 1971 or 1972 engine. I looked up the timing settings , but some say 8 degrees ; some say 10 degrees. I also put an electronic distributor in. In some instances, it seems to ping. I wouldn't think an electronic distributor could ping. Does anyone know what I should time this engine at?
  #2
Old 06-24-2004, 12:58 PM
gpeak's Avatar
gpeak gpeak is offline
Old 06-24-2004, 02:46 PM
87442lover 87442lover is offline
Grumpy
Early hi compression 455, 12 deg. initial advance. 36 deg. total advance by 3000.
Advance the timing as much as possible at idle till it pings, or starts missing than back the timing off a bit.
Old 06-25-2004, 11:05 AM
to gpeak 455 timing
Hi gpeak . I went to the web site on your response; I didn't know what I was looking for. Could you elaborate? thanks
Old 06-25-2004, 11:46 AM
MRGM MRGM is offline
Im trying to have an idea!
20° for starters. then try the factory 12° and see what happens
www.oldspower.com
www.realoldspower.com
i really do not like the 442.com
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
