Olds 455 Timing Marks/ - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2004, 02:22 PM
Where the hell are they? I got marks on the damper, but nothing to compare them to. Possible I dont have one?
Old 12-18-2004, 04:41 PM
BOBCRMAN@aol.com's Avatar
Some Oldsmobiles use a plastic timing indicator attached to the timing cover. It may have been broken off. I've seen it a bit on the core engines I buy.
Old 12-18-2004, 10:55 PM
New Member
timing marks
What year ?
Old 12-20-2004, 02:02 PM
its in my 74 cutlass
Old 12-23-2004, 08:31 PM
New Member
timing gauge location
1974 should be on the timing cover to the right and below water
pump 1976 and up have a timing gauge bracket including an eyelet for magnetic pick-up mounted straight up and below water pump. Shine flashlight downward behind the water pump to reveal gauge. If it is not present use a fully electronic timing
light
