Olds 455 vs. Pontiac 428??
I have a 69 Firebird, originally a 350 car, but the 350 was replaced with a 67 428 from a catalina. The swap took place sometime in the early 70's. The car runs ok and I love a pontiac motor but it is growing tired as we speak. Definate need of a rebuild! I recently found a very solid Oldsmobile 455 from a 76 Delta. I was thinking to maybe do a minor rebuild on the 455, since it's already on the stand, until I could stick gobs of money into the 428 to make it perfect.(on a budget right now) But will the 455 fit into the 69 Bird and bolt up. The bird has the original 350 tranny yet. Or should I forget the Olds and stick with the pure pontiac? I am somewhat new at buiding motors so any imput or rebuild suggestions on either motor would be awsome. Thanks Rob
While I'm an Olds fan, the 455 is completely different externally from the Pontiac motor. The only thing that WILL bolt up is the bellhousing. The motor mounts are different. You'll either need to fabricate something or find the mounts from a 73 or 74 Olds Omega with the Olds 350 motor (the Omega subframe is virtually the same as the one in the first gen F-body cars). All the accessory brackets will be different and the accessories may be located in different places. The exhaust will be different also.
I like 'em both but keep your Pontiac all Pontiac. PLEASE!
Oh and Joe is quite correct.
Heads
OK THANKS. Ill stick with the pontiac then. Any suggestions on a rebuild. Hoping to get 400hp without killing wallet. Should I have the heads ported/polished or invest in Edelbrock new? Prolly bore cylinders .030 over, or can I get away with more. Piston and cam suggestions???
| Pontiac 400 vs. Pontiac 455 | chevyelc81 | Engine | 7 | 03-19-2011 07:31 PM |
| olds 455 | oldscutlass | General Rodding Tech | 7 | 01-01-2005 11:34 AM |
| olds 455 | oldscutlass | Engine | 6 | 12-13-2003 12:03 AM |
| Olds 455 vs. Pontiac 455? | bildo95 | Engine | 3 | 06-27-2003 04:53 PM |
| will a 1969 455ci olds engine bolt right in place of a pontiac 400??? | chevyelc81 | Engine | 3 | 06-12-2002 03:54 AM |
