olds 4a heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2009, 09:19 PM
olds 4a heads
Can the olds 403 heads be ported to flow numbers that will support 500 hp? Is it true that the stock 4a heads intake flow more than the c heads and its the exhaust that really chokes the 4a heads? I would be installing 2.075 int valves and 1.710 exh valves.
Old 12-19-2009, 10:08 PM
amx180mph's Avatar
Cunningham and Hersh Hot Rods
Try this web pagehttp://www.mondellotwister.com/ArtUnsungH.htm
Dale
Cunningham & Hersh Hot Rods
Trick Flow super 23 heads for 383 elcaminodragster Engine 8 08-30-2009 12:59 PM
Olds 350 1971 heads - valves - HELP! bandit79jun Engine 18 12-23-2008 05:11 AM
Olds 403 will 330 heads work? Ulysses 2 Engine 7 05-09-2008 07:28 AM
79 trans am camaroking383 Transmission - Rearend 9 07-17-2006 01:35 PM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 01:16 PM
