-   -   olds buick 231 p/s pump onto an olds v-8? (http://www.hotrodders.com/forum/olds-buick-231-p-s-pump-onto-olds-v-8-a-173615.html)
fast68 02-26-2010 12:15 PM
ive got a low miles p/s pump setup from a 1985 cutlass 231 car i stripped and junked.
will it fit any v-8 engines?
or is it scrap metal?
thanks
joe_padavano 02-26-2010 04:16 PM
The Saginaw pumps with integral reservoir are pretty much interchangeable. You will need to get the Olds brackets, since the V-6 brackets are completely different. The pulley needs to come off to change the front bracket, and you may need to change it for the Olds motor anyway.
fast68 03-04-2010 06:55 PM
ok so brackets are unique to that engine hmm :(
good to keep for the lower mileage pump anyways..
thanks
joe_padavano 03-04-2010 07:07 PM
Actually, the PS brackets on any 1968-1990 RWD Olds V-8 are the same. There are two spacers between the bracket and block that you need as well.
