olds buick 231 p/s pump onto an olds v-8? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2010, 11:15 AM
fast68's Avatar
likes chevy trucks & boobies
ive got a low miles p/s pump setup from a 1985 cutlass 231 car i stripped and junked.
will it fit any v-8 engines?
or is it scrap metal?
thanks
Old 02-26-2010, 03:16 PM
The Saginaw pumps with integral reservoir are pretty much interchangeable. You will need to get the Olds brackets, since the V-6 brackets are completely different. The pulley needs to come off to change the front bracket, and you may need to change it for the Olds motor anyway.
Old 03-04-2010, 05:55 PM
fast68's Avatar
ok so brackets are unique to that engine hmm
good to keep for the lower mileage pump anyways..
thanks
Old 03-04-2010, 06:07 PM
Actually, the PS brackets on any 1968-1990 RWD Olds V-8 are the same. There are two spacers between the bracket and block that you need as well.
Chevy block interchangeable with Pontiac / Olds/ Buick JACK Engine 10 04-20-2011 07:16 PM
92 Buick power rack pinion using 68 Ford pump? JAY221 Suspension - Brakes - Steering 2 09-14-2002 11:21 AM
Wanted: 1959-1964 GM (caddy, buick, olds, etc) POWER VENT WINDOW MOTORS KUSTOMRYDER Hotrodders' Lounge 0 03-15-2002 06:23 PM
Wanted: 1959-1964 GM (caddy, buick, olds, etc) POWER VENT WINDOW MOTORS KUSTOMRYDER Interior 0 03-15-2002 06:22 PM
Wanted: 1959-1964 GM (caddy, buick, olds, etc) POWER VENT WINDOW MOTORS KUSTOMRYDER Electrical 0 03-15-2002 06:21 PM
