Olds and Chevy Harmonic Balancers - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2002, 03:11 PM
Question Olds and Chevy Harmonic Balancers
Does anyone know if the two balancers are the same seeing that they are both 350ci GM small blocks? I cant find anyone with the Olds balancer in stock. They all say it is not available(NAPA too).Any Info would be appreciated!
Old 08-20-2002, 03:26 PM
SAE Member; ASE Master Cert
Post
No, there is a huge difference between the 350 Chev and 350 Olds engines. Balancers will not interchange between the two engines.
Old 08-20-2002, 03:33 PM
Unhappy
So I wonder what gives then? The only balancer I can find is a FluidDamper and it runs $403!! Certainly there has to be somewhere that carries this balancer in its OEM form.
Old 08-20-2002, 03:41 PM
Post
See if you can locate a company called Silver Seal. They are located in one of the Detroit suburbs, can't remember where and I am currently sitting in a motel room so I don't have their address handy. They sell all kinds of stuff for automotive machine shops and have some hard to find things like original equipment oil pans, timing covers, etc. I think I remember seeing harmonic balancers in their line as well. Good luck.
Old 08-20-2002, 03:43 PM
Post
Thanks EngineGuy! I'll look them up in the morning and cross my fingers!
Old 08-20-2002, 04:08 PM
New Member
Post
Used to mess around with Oldsmobile's a little and found that many parts between the Olds V-8 family are interchangeable. 330, 350, 403, and 455. Never tried to replace a balancer on one, but you may ask the parts guy for a different engine size balancer if the crank snout is the same size. Just a thought.
Old 08-20-2002, 10:10 PM
aka Duke of URL
Arrow
-Damper Doctor-
Old 08-21-2002, 02:19 AM
225buick's Avatar
Post
I got one for my 403 from GM parts. it was a little over 100 dollars
