olds engine ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2012, 09:29 PM
rbp rbp is offline
olds engine ID
hi everyone...
I need to find out this engine specs that I just got. These are my casting numbers: 34R178608. The guy that I got it from said that its an Olds 350 from early 1970's. I was searching on previous postings and followed some recommendations of different places with information to come up with the specs, but with no luck. thank you
Old 06-05-2012, 02:45 AM
DoubleVision's Avatar
I get nothing on anything in the entire GM line with those numbers. That looks more like a VIN number stamped on a block than a casting number. Do a search on the web for Oldsmobile casting number locations.
Old 06-05-2012, 07:50 AM
455olds's Avatar
Post the numbers behind the water pump.
Old 06-05-2012, 04:04 PM
rbp rbp is offline
The numbers by the water pump are 395558. I hope that helps Thank you.
Old 06-05-2012, 06:18 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Casting number 395558 is a 1968-'76 Olds 350 block, according to the info I have.
Good luck.
Old 06-05-2012, 06:22 PM
rbp rbp is offline
Thanks man. Big help.
Old 06-05-2012, 07:27 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
By the first numbers you posted (34R...), it is a 1974. 3 = Olds; 4 = '74; R = assembly plant code, Arlington, TX.
The next six numbers are a partial VIN.
Good luck.
Olds engine ID help please!!! Deadmetal Engine 6 01-03-2011 11:00 AM
How to tell what olds engine? Meka Engine 1 04-14-2004 08:05 PM
350 Olds Engine on Any Olds 7skylark6 Engine 8 12-12-2003 06:17 PM
olds engine help oldblue4x4 Engine 3 03-24-2003 07:17 PM
olds engine help oldblue4x4 Engine 0 03-24-2003 12:03 PM
