Olds Rear End - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 12-06-2004, 03:07 PM
Olds Rear End
I HAVE A 70 OLDS CUTLASS I AM CHANGING THE REAR END GEARS FROM 2:56 TO 4:10 WHAT CARRIER WILL WORK IN THIS REAR END. THANK YOU
Old 12-06-2004, 03:11 PM
Max Keith's Avatar
olds rear
Isnt that an integral rear end, where the gears mount directly into the center of the housing vs using a pumpkin?
Old 12-06-2004, 03:44 PM
poncho62's Avatar
Wiki Edits: 5
Re: Olds Rear End
You will need the 4 series carrier. I think that the 2.56 uses the 3 series. You can get a spacer, instead of having to find another one. I did that when I went from 3.08s to 4.10s in my 70 Chevelle. It had a 12 bolt....................is yours?
Ontario Rodders
« 383 stroker | Scams »
