olds rearend question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2003, 12:27 AM
Post olds rearend question
I'm restoring a 1931 ford coupe with I'm told is a early olds rearend. About 1968/1969. Can I indetify the rear from the center section serial numbers and if I can where can I look to get replacement parts for the brakes and wheel cylinders? Any help would be appreciated. John
Old 03-13-2003, 02:47 AM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Post
Hi John try this site:www.oldsmobility.com scroll down to rearends click on that page may help,then go down to the bottom of that page gm 10 bolt rearend tech info hope this helps
[ March 13, 2003: Message edited by: zonk ]</p>
Old 03-13-2003, 07:13 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
If it is a nostalgia rod, built in the 60s or 70s it might have a '57 - '64 rear end. These were the desireable units for Gasser drag classes. Is it a Hotchkiss (removeable pumpkin) or Dana (gear carrier ntegral with axle tubes, removeable sheet metal back plate)? Former is likely the earlier vintage.
Old 03-14-2003, 08:26 AM
WoodsEdge's Avatar
Post
Zonk, couldn't get anything to come up. Is that the correct add??
Thanks, Jack
Old 03-14-2003, 08:37 AM
zonk's Avatar
Post
Hi Jack,this what coming up on address,first I went:www.oldsmobility.com,next for rear ends:www.oldsmobility.com/reardiffs.htm,for the 10 bolt tech,www.oldsmobility.com/10bolt-tech.htm zonk
Old 03-14-2003, 09:09 AM
WoodsEdge's Avatar
Post
My bad, I must have typed it wrong the first time.
Thanks again, Jack
