Olds roller rocker qeustion - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2011, 01:15 PM
hey guys, new here.
background info:
i have a 82 Buick century with the Olds 4.3 v6 diesel. i converted the rocker arms over to a set of Harland Sharp rollers. this diesel uses the stock roller cam, and Olds 307 style roller lifters.
the problem:
im not getting oil flow to the to the rockers. im using a set of oiling trick flow hardened push rods, and the fit both the lifter and the rocker cups great. the lifters are oiling ( i have the manifold and covers off right now) and oil is coming out of the top if the lifter. so everything below the push rods seems to be working right.
my question is can i drill a hole in the oil control plate in the lifter. (the one that controls oil flow to the push rod and rocker) to gain more flow? if i remove this plate the rocker oil fantastic. but i don't want to do all 12 of them and find out i have no oil pressure. i did start the motor and i had 60psi at idle (750) using a mechanical gauge, 80 psi when revved to 2500 (red line is 3700).
has anyone had problems like this before on a motor?
here is a few pictures:
specs are:
.020 over bore
total seal rings
arp rod bolts (BB Chrysler)
Full balance job (rods, pistons, crank)
Old 10-16-2011, 03:15 PM
Oil can only flow up the pushrod when the hole in the rocker and the hole in the pushrod are lined up.
Maybe the pushrods are too long?
Old 10-17-2011, 08:00 AM
Sorry, I don't have anything useful to add to your post, but all I can say is WOW! This is very cool in a perverse sort of way. Talk about dare to be different - and you're using a manual trans! I've been a Olds guy for decades and this is only the third V6 diesel that I've ever seen. What are you putting it into?
38 olds inner rocker ? 38 old coupe Body - Exterior 1 01-13-2009 06:02 AM
Roller Rocker vs. Roller Tip Rocker Ozz1967 Engine 15 01-08-2008 04:53 AM
roller rocker 1.5 to 1.6 tomthecomic Engine 6 12-23-2007 04:33 PM
Roller rocker (?'s) on 5.7 scheetz93 Engine 15 04-24-2005 07:20 PM
Roller Rocker ? onehotchev Engine 5 11-14-2003 11:50 PM
