Olds silhouette 4t60e periodic no downshift at stop - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2009, 10:33 PM
Mad_Max's Avatar
I have a 1998 olds silhouette w/ 4t60e and it will periodically have what I call a "no downshift at stop" condition. Basically as you come to a stop it does not seem to drop all the way down to 1st. It feels like you're taking off in 2nd, a firmer press on the gas causes it to go to 1st (or its engaging harder) No codes. Trans was replaced at 106K with a reman, now has 154K.
Ideas?
Old 07-26-2009, 10:52 PM
OLNOLAN's Avatar
Dirty Throttle Body
You probably just need to clean your throttle body. This happens on my truck sometimes. The crud line that builds up keeps the throttle butterfly from fully closing. This in turn throws the TPS off. The computer won't downshift first if it still senses throttle opening. Use B-12 chemtool cleaner, it works great. Make sure you use eye protection when spraying the cleaner. olnolan
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
93 and 94 olds 98 wiring pinouts 4t60e Ninja2000 Transmission - Rearend 0 11-19-2007 01:46 PM
My new 700R4 locomark Transmission - Rearend 11 07-05-2007 11:17 PM
