Olds stud pattern to chev. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2010, 03:31 AM
Im putting some disc brakes on my brothers 57 Olds 88 and want to change it to the more common 4.75" chev stud pattern at the same time. Is there a rotor/bearing combo that fits straight on, or am I going to have to get some sizes and head off to the bearing shop to dig out some oddball bearings from them?
Old 07-04-2010, 11:05 AM
BOBCRMAN@aol.com's Avatar
Convert to roller bearings (kits are available) and re-drill hubs for smaller pattern. Most of these old front spindles are wrong length for later model stuff.. Have to be machined.
Old 07-06-2010, 01:11 AM
Looks like Willwood do a complete disc conversion kit after all, will be the easiest way if they do.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
How to Make a good Pattern From a Bad Original DanTwoLakes Interior 6 05-25-2009 10:31 PM
standard bolt pattern on duel pattern heads nskeeter99 Engine 1 02-15-2009 01:41 PM
85 Olds to Chev fan shroud problem oldsmo Engine 4 03-26-2006 08:45 AM
chev 350 and olds 350? flatheadfever Hotrodding Basics 3 02-13-2006 05:02 PM
