oldsmobile 330 heads on an oldsmobile 305 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2003, 04:55 AM
Post oldsmobile 330 heads on an oldsmobile 305
I read once that you can swap oldsmobile 330 heads onto an 85 olds 305 block. It said the bolt holes had to be drilled to make the heads fit. has anyone heard of this or know if a 330 crank will fit a 305? Im possibly looking to stroke my 305 in my 85 oldsmobile 442. It's supposed to make one mean 305 and with the drive line and handling package of the 85 olds 442 it should make a killer street cruiser.
Old 04-29-2003, 05:09 AM
Post
oldsmobile is the 307 not the 305. my mistake.
Old 04-29-2003, 06:07 AM
Andrew7dg's Avatar
Post
I have not accually heard of that done. I know the 330 crank is forged and you can swap it into a 350 easily.
I believe what you should do is find an olds 350 or 330 block because they swap in place of the 307 and if you do it right it still would look stock but with a lot more horse i think that would be best instead of trying to stroke the 307. if you use the heads off of the 330, you will have to run lead additives untill you got work done to them.
Old 04-29-2003, 06:29 PM
New Member
Post
just put in a 455 olds install a decent cam put on a aliumin intake run about 10.1 compression you will have 400 horse power and 525 foot pounds of torque.
Old 04-29-2003, 08:47 PM
NAIRB's Avatar
Post
If you have a 330 Olds, put it in instead.
Old 08-10-2009, 09:35 PM
all 2nd gen olds small block shared the same stroke of 3.385 in. so it is impossible to stroke a small block with interchange parts the 260 all the way up to the 403 used the same stroke
Old 08-11-2009, 03:01 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
HERE'S a thread on the 330, etc. that explains some of the in's and out's of using the forged crank in other Old's engines, as well as links, etc. to info on building the 330 as a 330 or just using the crank.
Were it me, I'd use the 330 as a 330 and replace that 307 w/it. But a 350/455 is also an obvious option.
Good luck whatever you do.
Old 08-11-2009, 09:20 AM
For the money you will spend on trying to improve the 307, you can swap in a larger SB Olds(330-350-403) and be miles ahead. The 330-350-403 is a direct swap for the 307, uses the same mounts, pulleys, accesories from the 307. The 307 just has too small of a bore to make any kind of real street power, only used for Super Stock or Stock class racing, very expensive builds, and spun to a very high RPM to achieve any real gains, not exactly what you want for a street driven car.
Old 08-11-2009, 10:37 AM
All of the comments above are good ones, but to get back to the original question, yes you can swap 330 heads onto a 307. The biggest difference is the head bolt size - the 330 uses 7/16" head bolts and the 307 uses 1/2" head bolts. You need to open up the holes in the 330 heads. The other possible issue is pushrod clearance in the head. Most 330s used a unique 45 degree lifter bank angle, whereas all Olds motors built from 1968-1990 use a 39 degree lifter bank angle. This changes the angle of the pushrod and may require slight enlargement of the pushrod holes in the heads.
The bigger question is, why bother? The combustion chamber sizes are comparable between the 330 and 307 heads. The 330 heads do have larger ports than the peanut-port 7A heads used on the 1985-1990 307s, but you'd need to change intake and exhaust manifolds to make this work. All in all, it's a lot of work for very little effect.
