Oldsmobile casting numbers? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2003, 04:00 PM
I just got an oldsmobile motor, but i dont know where to look for the casting numbers. on the bellhousing it has 129 on it, but i cant find anymore numbers. anyone know where i can look or know what kind of engine it is? Thanks.
Old 09-26-2003, 04:20 PM
bonuts's Avatar
Got Ouzo for touzo
I believe the Olds heads are not numbered, but they're lettered. I have a few Olds motors from running circle track. Check these guys out for answers to Olds questions, I'm sure these are the guys who helped me out. Could be wrong though.
bonuts
Old 09-26-2003, 04:21 PM
ummm what guys? lol
Old 09-26-2003, 05:38 PM
bonuts's Avatar
Got Ouzo for touzo
http://www.mondellotwister.com/
Oops, these guys
Old 09-26-2003, 06:59 PM
wp442's Avatar
Last journal entry: Feb. 03, 2006 - Bed repair 05
The engine casting number will be located on a large flat area just above the water pump. The heads are either number or lettered in large digits in the top corner, very obvious from just taking a quick glance at them. Number designate small-block, letters for big blocks. Post what you find and I'll help you out.
Old 09-26-2003, 09:57 PM
the engine is completley assembled except for the intake manifold so i couldnt get the head numbers/letters. the casting number is 3161GM50L. thanks
Old 09-27-2003, 02:47 PM
wp442's Avatar
What you have there is a 1985-86 307. Hope you didn't pay much (if anything) for it.
Old 09-27-2003, 04:12 PM
wp442's Avatar
whoops...double post.
Old 09-27-2003, 07:44 PM
i tryed a 83 fleetwood with a 4.1 v8 in it
Old 05-23-2009, 12:09 PM
can anybody help me indentifi an olds motor numbers off block are 557752-3b
Old 05-23-2009, 12:19 PM
http://www.oldsmobilewiki.com/index.php/Category:Blocks
That's a 77-80 350 with windowed main webs.
bonuts
You believe incorrectly. Besides the casting ID letter (big block heads) or number (small block heads) next to the first spark plug, there is also a six digit casting number above the center two exhaust ports. This is important because people have been taking common "E" code heads, grinding off the bottom of the "E", and trying to sell them as the rare and very expensive "F" heads used on the 1970 W-30. Fortunately the casting number above the exhaust ports is different and not easily changed.
Old 05-25-2009, 10:12 AM
thanks, the numbers above the exhaust ports are 554 716
there is also 3a on the front corner of the head
Old 05-25-2009, 10:49 AM
Also 1977-1980 Olds 350.
http://www.oldsmobilewiki.com/index....vative_Numbers
Old 05-25-2009, 12:30 PM
Olds problems
Go to Oldsmobile FAQ and they can tell you a lot I've been running Olds for a number of years The heads have had letters-numbers-and both together depending on years the main ones to stay away from for performance are 73-76 and any thing in a 307 Olds newer than 84.1985 and up 307 junky enginesdont even fool with them doesn't matter what it came from junky.Lefty
