OLDSMOBILE in need - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2006, 07:34 PM
OLDSMOBILE in need
I have a 1961 olds 98 holiday and want to put new brake lines from inlinetube.com in the old girl but hey only have a brake kit for a 59 olds of the same wheel base does ant one know if it will fit in the 61 ??
Old 12-01-2006, 09:00 PM
As a Moderator here ...
I want to WELCOME YOU to Hotrodders.com
I do not know if the 59 is the same as a 61 ... but I always bent up my own and then double flare the ends after I make a duplicate ( to the original ) tube. Quite simple really ... especially with just a little practice.
Again WELCOME ...
Deuce ... Moderator
Old 12-01-2006, 10:09 PM
Right On!
thanks for the reply. It was the hoses i was thinking more along the lines of
running from the hard lines to the drums...
oldsmobile 330 heads on an oldsmobile 305 JohnnyBoy Engine 8 08-11-2009 10:37 AM
Oldsmobile engines. Meka Engine 22 06-27-2007 03:16 AM
Source for Oldsmobile distributor compatibility? jimra1944 Electrical 2 09-07-2005 07:42 PM
Oldsmobile F-85 starting problem oldsF85 Engine 1 03-29-2004 07:21 PM
What kind of oldsmobile Rocket is this Silentlion_69 General Rodding Tech 2 03-12-2004 08:02 AM
