Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - omni epoxy coat problems?
Old 03-17-2012, 02:02 AM
inkfreak1976 inkfreak1976 is offline
Originally Posted by mitmaks
Possibly had too much air and you pretty much blasted it on. I'm not sure how long you've been spraying but every product that I spray is a little bit different and I have to make adjustments. I've been painting for many years too and do it on daily basis.
When spraying something as big as a car or even just a single body panel make necessary adjustments to the gun and to a spray out on the piece of cardboard/scrap, don't just go shooting car and make adjustments on the car.
i shot on a tester paper that i had taped to the wall, pretty much everytime i started to have problems, i would make the adjustments if necassary. but that got to be every 20 sec. and i knew that if i didnt get going on it i was going to lose my wet on wet, so i did the first coat the best i could. basicly adjusting my speed to get as wet of a coat as possible. i decided to do a second coat because it came out tiger striped as all hell and i knew i couldnt leave it like that so i knocked down my pressure 20 lbs did a test and it sprayed like a dream on the test paper. so i thought that i was good, and im not talking a couple trigger pulls i lined a good part of my wall with 18 inch paper and it shot awesome perfect fan perfect material application. and did several passes. oh and at that time i also splashed in some extra reducer and mixed strained, and cleaned gun before second coat and test. it was good so i started on the car and the same crap happened not 30 sec later so i did the same thing slowed my speed and tried to get the wettest coat i could, still tiger striped after the second coat and following proper flash times. i decided to do a cross pattern to try and blend the stripes. it filled in the stripes , but did the same thing. so i stopped cleaned up and let it cure over night. the plan was to do base and clear the same day but the way it sprayed i didn't want to risk the base and clear until i knew what the out come was going to be thanks god for gut instincts.
