Omni MP213 verse MP180 Help, need feedback fast! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2006, 09:11 PM
HELP!!!! I want to get my car painted this weekend! My problem is this! I used 2 different paint suppliers! I asked for PPG sealer and I told them I was shooting Deltron DBU base! One supplier sold me Omni MP180 with hardner! My son went to the other supplier. I told him to get sealer for me! He came home with what they gave him Omni MP213 and MR186 reducer! (My fault I know) Will these be ok to use under DBU? Also, will they work ok with each other! Everyone is now closed for the weekend, so I turn to you folks for help! Thank you!
Old 04-28-2006, 10:35 PM
Wiki Edits: 49
After checking the "P" sheets for DBU neither OMNI products are recommended.
Go to the PPG website and check the Product Sheet ("P" sheet) for DBU under the automotive refinish section and it will give you the proper substrate material recommended for that topcoat.
Old 04-29-2006, 12:21 AM
oops, double post
Old 04-29-2006, 12:23 AM
I checked the tech sheet also, and the mp180 isn't listed as an undercoat under the mp213. I don't know why it isn't listed, both the omni epoxy primer and 2k urethane surfacers are. But if you already used the mp180 why do you need another sealer? This is a non sanding sealer mainly used just prior to paint. Using the 1k mp213 would be taking a step back compared to a 2k product. I have never used the mp180 under anything but omni products, but have used the omni epoxy primer under deltron base before without incident. Many years ago I use to use velvaseal (another 1k sealer) under deltron base without problems either. I just don't see the point of using the 1K sealer over the 2k.
'http://www.ppg.com/refinishftpsite/docs/ob31.PDF'
Omni Verse Delstar Ron M Body - Exterior 4 08-06-2004 06:02 AM
