-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   Once again, bending pipe???? (PIC) (http://www.hotrodders.com/forum/once-again-bending-pipe-pic-136578.html)
djjc76 04-07-2008 03:25 PM
Fellas, I am attempting to bend pipe. I will need the pipe to be 1 1/4" in OD, .065" wall thickness (yes, thin) and seeking a smooth 90 bend. I am going to try and pack the pipe with sand and cap the ends with duct tape. I just wanted to see if anyone out there has had success in the area. Thanks.
The parts I want to make are the water outlets off the flathead motor, which point to the radiator.
http://img.photobucket.com/albums/v5...1a34ce97a9.jpg
48ChryslerRodder 04-07-2008 03:47 PM
You might try an electrician shop. They have conduit benders that can create a fairly smooth 90.
Jake_Dragon 04-07-2008 04:01 PM
Haven't had to do it in a while but we used that bending method in the Navy. found a nice pipe the right size and bent the pipe around it. Used some wood "corks and cloth to seal the ends. Worked well with a little heat. Not too much or you will crush the pipe.
For cold bending we used ice.
djjc76 04-07-2008 04:01 PM
thanks..
I didnt even think about that...thanks!
justold 04-07-2008 05:35 PM
without the proper bending shoes you are going to have a poor job at best . A conduit bender is going to be a rather large radius bend , a 1.25" 90* is about 10 or 12 inches from back of bend . I would go to the local muffler shop or buy some prebent and strait peaces and weld them up .
What is that motor , a Cadillac ?
djjc76 04-07-2008 05:54 PM
caddy
yes, it is a '39 LaSalle engine, 322cui
kruzr 04-07-2008 06:25 PM
Nice looking engine,can;t remember last time I saw one of those beauty's
You can also buy the bends they make for headers, nice tight bend, then weld em up.
powerrodsmike 04-07-2008 10:08 PM
I can tell you from experience that with .065" thinwall material you won't get a bend less than 10" or 12" centerline radius without busting the pipe...When you fill it with sand, the outside wall of the pipe stretches around the bend. The wall thickness is not thick enough to stretch that far, and heating thinwall evenly to bend it is hard to do..it just doesn't stay hot long enough to get the bend done..
You could try to do it in small increments, and maybe if you have a bunch of patience, you can get a smooth 90*. It still won't be a tight bend.
Use thick material, at least .125" wall, and fill it with sand or steel shot. You still won't get any better than 5 or 6 X the diameter if you use a bender of some type.
Or do as others have said...buy the pre-made mandrel bends. A mandrel bent tube can have a centerline bend radius as small as 3X the diameter of the tube. If you look around you can find them in SS too. I'd buy the U bends, they have a long leg and can save you a weld.
Conduit bender won't do pipe or tube correctly,, unless you have the right dies...the conduit is sized differently than pipe or tube and the wrong dies will kink thinwall . ( Besides a Hossfield #1 bender , I have 2 Greenlee conduit benders in my shop. An old hydraulic incremental as well as a nice one shot bender. I know what they will do.)
Later, mikey
Jake_Dragon 04-08-2008 12:41 AM
Thats what we did, laid out 1 inch segments and heated it one segment at a time. It took a long time to bend and it didn't produce a smooth bend but it did bend.
RPM 04-08-2008 08:08 AM
You need a tubing bender to do that so it looks good. There are plenty of race car shops in Cal. There should be one fairly close that could bend that for you. If not I would buy some J bends for building headers and cut and weld. A muffler shop will crush bend that tubing and it won't look good, if they can even do 1 1/4"
Also what about sink drain tubing? I think it is about 1 1/4 and it is chrome.
djjc76 04-08-2008 10:31 AM
Thanks fellas...Hmmm...dont they already make prebent 90 SS piping???
scrimshaw 04-13-2008 06:03 PM
Hi djjc
I have made 1.5" headers by using packed sand and renting a tube bender. It takes a bit of patience but you can make a very nice bend. The trick is to use totally dry sand (dry it in the oven if you have to) and pack it as tight as possible. Cap one end by welding it if you can, then fill and tap the pipe to settle the sand. I was told to tap with a solid object for one hour per inch of diameter, not sure if I did it for this long though!!. Then ram a piece of wood ( I used a potato!!) in the other end. Material was stainless, can't remember what the thickness was.
techinspector1 04-19-2008 01:48 PM
http://www.burnsstainless.com/
BAILEIGH 01-02-2009 10:44 AM
This application is a mandrel bender application unless you want a fairly large radius bend.
To bend 1 1/4" x .065" mild steel "empty" (with no mandrel inside of the tube) you will need to bend it to at least a 4.25 CLR (center line radius)
dalesy 01-02-2009 04:38 PM
I think you can buy pre-bent conduit 90's in different sizes at Lowe's or Home Depot, or electrical supply.
