Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Once again, bending pipe???? (PIC)
Old 04-07-2008, 04:01 PM
Jake_Dragon's Avatar
Jake_Dragon Jake_Dragon is offline
Last journal entry: New Carb
Originally Posted by djjc76
Fellas, I am attempting to bend pipe. I will need the pipe to be 1 1/4" in OD, .065" wall thickness (yes, thin) and seeking a smooth 90 bend. I am going to try and pack the pipe with sand and cap the ends with duct tape. I just wanted to see if anyone out there has had success in the area. Thanks.
The parts I want to make are the water outlets off the flathead motor, which point to the radiator.
Haven't had to do it in a while but we used that bending method in the Navy. found a nice pipe the right size and bent the pipe around it. Used some wood "corks and cloth to seal the ends. Worked well with a little heat. Not too much or you will crush the pipe.
For cold bending we used ice.
