Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - One air mixture screw no adjustment.
  #17 (permalink)
Old 09-24-2012, 07:00 PM
RWENUTS's Avatar
RWENUTS RWENUTS is online now
Originally Posted by 350 View Post
Not sure to be honest I don't have any timing tape or a any way to set it the timing the little plate that is used to set it is gone. Gotta set it by ear. Bad idea I know. And what should I do first?
No timing tab. Did you look behind the water pump. At 12 oclock. Some had them there.
Or do you have a chrome timing cover?
Like I said drive it with it hooked to manifold, tune the carb screws and see if the bog is curable by adjusting the pump stroke.
You can get bolt on timing tabs.
And good timing lights for 60 bucks.
The Following User Says Thank You to RWENUTS For This Useful Post:
350 (09-24-2012)
