One air mixture screw no adjustment. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-24-2012, 06:53 PM
350 350 is offline
Also I have gotten good at listening for spark knocking lol
  #17 (permalink)
Old 09-24-2012, 07:00 PM
RWENUTS's Avatar
Originally Posted by 350 View Post
Not sure to be honest I don't have any timing tape or a any way to set it the timing the little plate that is used to set it is gone. Gotta set it by ear. Bad idea I know. And what should I do first?
No timing tab. Did you look behind the water pump. At 12 oclock. Some had them there.
Or do you have a chrome timing cover?
Like I said drive it with it hooked to manifold, tune the carb screws and see if the bog is curable by adjusting the pump stroke.
You can get bolt on timing tabs.
And good timing lights for 60 bucks.
The Following User Says Thank You to RWENUTS For This Useful Post:
350 (09-24-2012)
  #18 (permalink)
Old 09-24-2012, 07:05 PM
350 350 is offline
I got a timing light and no tab. Where we switched motors it wouldn't fit we put parts off of one on to the other. I can't remember y now. But I drove it today and it done good. Just that bog at the bottom. I only have about a half turn of adjusment on each one. Haven't moved the pump shot. I can't idle it up or I lose adjusment and it needs to have a little more idle. Lol u have been dead on so far so tell me where to start and I will. Sorry I am on a cell phone so its hard to type all this.
  #19 (permalink)
Old 09-24-2012, 07:17 PM
350 350 is offline
Also do I set timing with the vacuum advance plugged off
  #20 (permalink)
Old 09-24-2012, 07:54 PM
RWENUTS's Avatar
Always set timing with vacuum plugged off.
Get a vacuum gauge and tune your mixture screws with that. At 1/2 turn out you might be a little lean at idle now. If no gauge try at 1 1/2 turns out.
  #21 (permalink)
Old 09-24-2012, 07:58 PM
350 350 is offline
Ok can do. And. If I go more than a half turn out on the one screw the idle gets bad I can't go anymore either way.
  #22 (permalink)
Old 09-24-2012, 08:46 PM
350 350 is offline
In other words where I have it set is all I can get if I turn either one a half a turn it runs worse. And the one I am having issues with I can only go a half turn from all the way in and that's it can't go in or out and it get crappy. Sorry trying to get this whole thing down pat.
  #23 (permalink)
Old 09-25-2012, 07:31 AM
RWENUTS's Avatar
SEt them where it idles best!
350 (09-25-2012)
  #24 (permalink)
Old 10-02-2012, 04:49 PM
350 350 is offline
Ok been driving it a few days this week. And it runs really good now. However when I idle it up with the idle mixture screw I lose some the ability to tune it. If I idle it down its to low. So I got to get that figured out. But otherwise I got it going great. Thank you aging.
air mixture screw gaskets Oregonite Engine 2 03-23-2012 05:48 AM
Quick Fuel idle mixture screw adjustment Help Joe428 Engine 4 07-22-2011 04:09 AM
edelbrock mixture screw fast68 Hotrodding Basics 4 01-17-2011 09:28 AM
1 barrel air fuel mixture screw question cutthroatkid Engine 2 07-01-2010 07:34 AM
air screw adjustment? Trav Engine 6 09-29-2003 06:52 PM
