which one is better for novice - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2003, 02:19 PM
stoney 81ta's Avatar
which one is a better manual haynes or chilton
Old 12-27-2003, 04:06 PM
Rubberman2003's Avatar
Well if your talking about general manuals, id says Haynes..ex (how to rebuild your smallblock chevy). The car books arnt bad either, on the cars i cant really say for sure....pretty close.
If i HAD to pick, id say Haynes.
Old 12-28-2003, 07:36 AM
MoparTbucket's Avatar
Well, I use them both. I have often found info in one that wasn't in the other (yes, I have one of each for some vehicles). Fortunately, they are inexpensive (certainly compared to the other things we buy for cars) and you can never have too much info.
If you have access to a library, check out there auto reference section and it might help you decide which you prefer. I have used the large Chilton's books for info and just copied the sections I needed, the library usually has a copy machine so it's easy and inexpensive. I haven't tried to look up 37 chevy, but you should be able to find info on the 60's or later cars.
Old 12-28-2003, 07:54 AM
malc's Avatar
Living At The Speed Of Life
If I had to pick it would be Chilton, but I use both.
Chilton has more on computer codes and wiring than
Haynes.Haynes has good trouble shooting pages.
I didīnt use either for my engine build, I used a specific
"Workbench book" on small block Chevy.For the carb I use
Doug Roeīs Rochester carbs.
Canīt have too many books.
Old 12-28-2003, 01:03 PM
thanks all for your replies
Old 12-28-2003, 01:10 PM
poncho62's Avatar
Wiki Edits: 5
stony....You should also try to get the GM factory manual for your car. They are generally expensive, but seem to have more stuff in them. At least the older (60s) ones did. The one for my Pontiac even showed me how to put on a new convertible top.
Old 12-29-2003, 07:23 PM
Tazz
poncho makes and excelent point, the GM service manual is great. I use the chiltons when I can get them, more year specific. The Haynes is too general, tries to cover to may years like say 88-93 to many years to many differences in vehicles. I get the chassis manuals specific to your car they are good reference too. You get what you pay for.
Tazz
trolloligest
Rat Rods Rule!
Old 12-29-2003, 07:41 PM
info
a friend of mine uses a camera to take a record of the steps
pulling most things apart it has helped him many times especially when he must leave it and come back to it later
his other trick was to leave the tools he was using right beside the job this way he lost no time upon his return
Old 12-29-2003, 07:45 PM
poncho62's Avatar
Wiki Edits: 5
Re: info
I have always said that working on cars is 25% mechanical aptitude and 75% memory.............
Old 12-30-2003, 12:57 AM
malc's Avatar
I spend a good deal of time looking for tools.I tend to walk away from the job with a tool in hand,put it down and do something else.Then go back to the car and wind up retracing my steps.
I ought to book mark pages in manuals as I never refind info easily. 53 and shot!
Old 12-31-2003, 05:48 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Check out ebay for the GM service manuals, I got one for my Caprice for $7.00. And it is very informative.
Old 01-03-2004, 12:46 PM
M&M's Avatar
M&M M&M is offline
New Member
I have the same problem as malc, I spend 3/4 of my time looking for the tool I need. Also as I am just starting out there are lots of times I don't even have the tool I need.
M&M
Old 01-03-2004, 03:14 PM
malc's Avatar
To escalate the problem I leave my reading glasses in all sorts of places.
They shoot horses donīt they?
Old 01-03-2004, 03:20 PM
I got a reprint factory shop manual for my 65 tempest on ebay for $25 usd - invaluable resource for an older car
Old 01-04-2004, 11:21 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
For every car I have owned, and some I work on regularly-
I own both the Chiltons AND Haynes, because what one doesn't cover the other does (for the most part), and Haynes for Rochester carbs.
I also use the Clymer manuals for motorcycles, what little I do on them.
When I get rid of the vehicle the books cover, the manuals stay here with me.
I have a couple I can't remember where they went so I might have to re-invest in them.
