one clutch to many - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2010, 07:40 PM
one clutch to many
hi everyone i need some help i've put two center force clutches in a 69 camaro big block 4speed it has lite weight flywheel 336 gear do you think that is the problem its kind of hard to pull off
Old 03-31-2010, 11:03 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
"hi everyone i need some help i've put two center force clutches in a 69 camaro big block 4speed it has lite weight flywheel 336 gear do you think that is the problem its kind of hard to pull off"
Thank You for your service to our country.
Hi,
What are you talking about, I'm confused (nothing new there)
Do I think what is the problem? What is hard to pull off?
What do you mean when you say you put two clutches in?
you put one in, & then for some reason you had to take it out & put another one in?
Or are you talking about the Twin disc clutch from centerforce?
Old 04-01-2010, 07:38 AM
no had to replace the clutch and you have to ride the clutch to make it pull off with the z-28 flywheel
Old 04-01-2010, 11:56 AM
Wiki Edits: 85
I am confused.
How does riding the clutch cause the flywheel to pull off the clutch???
Old 04-01-2010, 02:54 PM
I think he means when trying to take off from a stop the clutch isn't locking up to the flywheel.
Old 04-01-2010, 03:08 PM
35chev/302gmc's Avatar
If you have a m-21 0r m-22 transmission with a 2.20 fisrt gear , I would thing you would have to do a little slippen to get the car rollen with that 3.36 rear gear. It would be even worst if you have a tall rear tire
1935 chevy,masters
Old 04-01-2010, 08:45 PM
owner said it came with 4.10 i mean the peddle fells good when new he drove it a few weeks it wore disc out can't fine any thing wrong with linkage un less he just can't drive it is a Muncie i was just wonder ing if the 3.36 and THE z/28 flywheel and2.20 is doing it tires maybe 27 tall
Old 04-01-2010, 08:55 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
It is that lite flywheel that is causing the issue I belive..a light wheel requires a lot of clutch slippage to get the car moving which then eats clutch disks...
Sam
Old 04-01-2010, 09:04 PM
i think thats it to but you know how some of these camaro guys are
Old 04-01-2010, 09:52 PM
It's both the insufficient overall gear ratio in low gear and the light flywheel causing your problem. I had the same flywheel in a '69 Nova with 26" tires, 3.08's, & an M-20 (2.52 low gear), and it was a real pain to get moving.
Changing to a standard-weight (~30lb) flywheel will make a big difference, but it's hard to find them since GM quit making them a while back. There are some Chinese ones around, but I can't bring myself to trust one, and race stuff requires a special disc, since a stocker won't clear the flywheel bolts for some reason.
I'd also look into a wider-ratio gearset for the trans, if you're not married to the 2.20 low for some reason, or maybe some deeper rear end gears.
Old 04-01-2010, 10:50 PM
thanks i really think your right
Old 04-02-2010, 08:02 AM
Side step her at 7000 she'll take off!!
Busted Clutch chrisflock Transmission - Rearend 1 04-15-2006 04:08 PM
Taurus SHO clutch issue... I know, big surprise... ViperMonster800 Transmission - Rearend 3 04-04-2006 09:33 AM
Clutch problems on 66 Mercury onebadmerc Transmission - Rearend 21 09-23-2005 04:21 PM
Clutch preload? RB401 Transmission - Rearend 0 08-03-2005 10:26 PM
Lakewood Clutch fork clip broke/angle of clutch fork 70bird Transmission - Rearend 3 04-23-2004 08:04 PM
