One hell of a time with Balancer - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2006, 07:22 PM
dpjmw's Avatar
This balancer on my 427 BBC is giving me hell. It acts like it don't fit, pulled it off and see a grove that I can feel on the inside of my balancer where it was trying to go on. Whats the deal? surely there is not a larger size to buy???!!! Can anyone tell me what I'm doing wrong?
Thanks, John
Old 09-03-2006, 07:44 PM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
balancer
How is the key way? Is the key to tall making the balancer too tight? Does it fit W/O the key? Try to narrow it down to the Key way or the outside dimensions of the crank or the inside dimensions of the balancer. I hope you checked for burrs.
Hope this helps Russ
Old 09-03-2006, 08:43 PM
runn141's Avatar
SB S10
if its aftermarket it may need some sanding inside it
Old 09-03-2006, 10:31 PM
BOBCRMAN@aol.com's Avatar
RUNN141 is correct. Virtually ALL of the aftermkt balancers are too small!! It is common to remove .001 + to get a proper fit.
Old 09-03-2006, 11:14 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
How are you trying to install it? Are you using an installation tool to press it on or just trying to slip it on by hand? The balancer should be a pressed on and will have an interference fit. Do not hone the hub to allow it to slide on by hand. Some cars do have slip on balancers but they are often held in place by much larger bolts and are torqued to as much as 130 ft lbs. The Chevy balancer is only retained by the press fit and a 7/16-20 bolt. You should obtain an installation tool if you don't already have one. Summit sells them under part number SUM-G1023 for $35.95, very reasonable. They work great. If there are no burrs, nicks or other damage to the crank snout or the inside of the balancer then lubricate the crank snout with a little bit of oil and press it on using the tool.
Apparently you can soak them in boiling water and install them as well...http://static.summitracing.com/globa...sum-161350.pdf
Good luck...
Old 09-03-2006, 11:27 PM
dpjmw's Avatar
Thanks for the replys!
I'm going to get the tool. I've talked to a couple of folks and after reading these replys - seems I need the tool to press it on. There are all of the hill-billy ways of getting one on, but I understand now that you are supposed to press it on. Thanks again
Old 09-04-2006, 12:04 AM
BstMech's Avatar
NYOFP4RJ3CHRIS
Before I took a chance and tried pressing on something that may have too much interference, I'd at least mic the old/new parts and compare.
I do know that if Bob offers an answer, it's real world (hands on) advice, not BS. I'm sure if you find any difference in size Bob (as well as many others on here) could give you a max interference measurement.
You might get that balancer on with that tool, but you may play he*l ever getting it off again with too tight a fit.
Only takes a minute to mic things and be sure........
283 Harmonic Balancer JamesD Engine 29 03-14-2007 05:36 PM
Serious problems removing harmonic balancer! spyderdude Engine 55 06-09-2005 10:01 AM
balancer bolt broke while driving, im 500 mi from home. Jared Engine 10 10-27-2003 11:13 AM
harmonic balancer install gkev Engine 1 09-08-2003 06:51 PM
sbc 327 vs 350 Harmonic Balancer Question Ted's37 Engine 3 07-14-2003 04:10 PM
