Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - One Idle Mix Screw Not Working!!!
Old 10-05-2012, 02:23 PM
RWENUTS's Avatar
RWENUTS RWENUTS is offline
Hook your vacuum advance up to manifold vacuum, turn down your idle. You've uncovered the idle transition slot too much with a high idle. Runs rich cause you're starting to run on the power circuit.
