This One Is Kicking My Butt - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2010, 08:05 PM
OLNOLAN's Avatar
Hey All, Working on a '97 BMW 318I. Former owners tried to do a starter job and botched it up. Found lots of stuff not connected, hoses, wiring etc. The two wires not connected are the puzzle. I found the Black/green is supposed to hook up to the aux. crank terminal on starter. The other wire is the puzzle, its brown/green stripe, the end got cut off. I think it was supposed to be a ground on the intake manifold somewhere, but I can't verify it with the diagrams I have. I have found reference to a brown/green(two) which are ground outputs from the ECM, one to the idle air control valve, the other to the fuel pump relay. Is the extra wire a ground source for the ECM? This ones kicking my butt! Any help would be appreciated! olnolan
Back side of a Mig Butt weld... lilgreenjeepyj Body - Exterior 16 11-09-2009 03:53 PM
Help Garage door opener kicking my butt! Rob Keller Garage - Tools 4 10-04-2009 08:22 AM
How To Do The Best Butt Weld ? SCHOONER Body - Exterior 10 06-29-2006 09:32 AM
Prep steps for painting butt weld lines. satexasf150 Body - Exterior 7 11-19-2005 08:32 PM
Eastwood butt weld clamps Meathead Body - Exterior 8 09-02-2004 08:43 PM
