solution
additional information is the mc is located on the frame. I just happen to be reading a magazine that had this very article and it suggested to use a hand held vacuum pump. Looks like I'm going to have to hit up my neighbor!
If it is a 59 it has a single master cylinder if it is original. You need to get that upgraded to a dual system. There are kits to accomplish this I am sure as there are a ton of those trucks on the road.
If the brakes worked fine when you parked it and now they don't, something failed. It is a sealed system and air should not be able to enter on its own. My guess is that original master cylinder probably has seals that have failed and can not hold pressure anymore. If you need to change it it would be wise to upgrade.
Artificial Intelligence is no match for Natural Stupidity Chet |
i've had problems with those speed bleeders leaking before.. they work ok.
Since I started bleeding the brakes this way, i've had nice firm pedals. if it's a new M/c. bench bleed it with the directions that come with it. once everything is in the car, I use a clear paint mixing cup so it doesn't melt with the brake fluid.. put a clear hose on the bleeder, put the end of the hose in the cup.. pour enough clean brake fluid into the cup to cover the end of the hose. open the bleeder pump the snot out of the brakes. but don't go crazy.. if you pump the m/c dry, you get air back in and have to start over again! once you are getting clear brake fluid from the bleeder, close it and move on to the next wheel. I don't know if it matters _that_ much. but every thing I've ever read on bleeding brakes always says start with the wheel furthest from the m/c and work your way closer.. on most cars that's RR, LR, FR, FL |
Start bleeding the brakes right at the outlet of the master cylinder. If you have adequate flow and pressure there, then move to the wheels. If not, then there you are, bad master cylinder...
Andy |
| bleeding brakes | yragat | Suspension - Brakes - Steering | 18 | 07-02-2008 05:32 PM |
| Muscle Cars | madhat | Hotrodders' Lounge | 140 | 03-08-2007 11:08 AM |
| question about mp brakes setup | 38 old coupe | Suspension - Brakes - Steering | 5 | 04-17-2006 01:18 PM |
| Question about Chevelle Brakes | JamesRS | Suspension - Brakes - Steering | 4 | 09-15-2004 09:28 AM |
